Made it worse? As in still popping? That should have fattened it up if it were lean? You sure you do not have an air leak?
When I pulled the enrichener very slightly to try and fatten it, it gets worse. I realize that this is a fairly big shot of fuel but just trying to see if it makes it better or worse.
Bodeen,
Sorry Your having Troubles with it working like I thought it would.:small3d023:
Is that carb Seated into the rubber gasket enough at the manifold?
Checking manifold seal with some WD40 tonight when I get home. I went together very nicely and seemed to seal good but I will check it.
