You did not answer my question. How do you know the fluid level will drop to the point it won't register on the dipstick if you are refilling to full every 100 miles?
The engine oil filler is not connected to the trans case, it is connected to the oil pan.Take a look at the attached diagram. The trans fluid is contained in the trans case and the oil is contained in the oil pan; two separate containments. The trans fluid drains from the trans case via a passage cast into the oil pan (red rectangle).
I'm thinking breather. When you are adding oil, do you always top it off to the full mark? If so, you could be losing it via the breather. I had that issue on my Road King. I kept seeing oil on the ground, and the trans level was lower then the last time I checked it. After checking everything I could think of, except the breather hose, I finally took a look at it. It was the only place I could be losing it from. Sure enough, after a long ride the end of the breather hose was wet.
Turns out I was actually over filling it. I drained the trans, and refilled with correct amount. I made a witness mark on the stick to indicate the "correct" full level. No issues or problems after that.
As stated in other posts if you're losing that much fluid you have a big leak that would be detectable under your bike OR 1 of the other holes is filling up with tranny fluid.
A simple test is add some dye or drain tranny and fill with Red line heavy, go for a long ride, recheck tranny and check the other 2 holes for levels and any seepage.
If no seepage is detected then there is something wrong with your calculations.
BTW, how are you checking the tranny level? on the jiffy stand or standing straight up?
Two great minds at work and on the same page. I just happen to be bored at the moment with not much else to do.![]()
I really do appreciate the time and patience you guys are giving up while helping me here !
Thank you very much !
On the jiffy stand Jeff , with the transmission and engine cold.
I leave it overnight and check it the next day.
Checking fluid level wrong. Unlike checking the oil level, transmission level should be checked with the bike upright and level and the dipstick "resting" on the threads, IAW, not screwed in. If the bike is on the jiffy stand, the trans fluid travels to the left side of the case and may not touch the dipstick.
The OP should start checking fluid accurately and report back. Still contend that a leak of 3.5 ounces in 100 miles should be leaving a mess somewhere.![]()
I stand corrected, I was thinking oil when I made my post.
