Last weekend ran a tankful of 91 pure gas in the bike didn't notice any difference in performance.
If I tried that on my bike, it probably would perform the same way also. Reason being on my bike, when the tank says "empty" I still have 1.2 gallons of fuel inside. I would just be diluting the mixure and not running pure gasoline.
Saying the bikes performance did not change is actually a VERY profound statement. Lets think this through for a moment. The Energy output per gallon of Ethanol is appox 76,000 BTU. The Energy output of reg gasoline is appox 119,000 BTU per gallon. Our world as we know it, exists based on physical laws, one of which is the Law of Conservation of Energy.
You may not feel it, but there is a differenece in performance. There has to be, it's a physical law of science.
But the bottom line is Live & let Live. No further comments regarding this topic from me. I promise.![]()
Was not aware of water injection in aircraft, I assume only in piston engines, curious, what is the max percentage?
The water injection is controlled by the pilot and as far as max %, couldn't tell you there, I only fixed them, not flew them.
It's a fish oil water combo that they use and it's distributed through a pretty elaborate carb on piston engines that uses balance chambers to lean out fuel when the water injection is applied on takeoff carrying heavy loads. With 4360 HP each of 4 engines , they need all the help they can get so they don't blow apart.
They were 28 cylinder engines, internally supercharged with 4 magnetos and dual plugs in each cylinder fired by independent coils. (double ignition systems). Real fun to set them up.
