I would need to know the facts...
How many miles per ride and how much oil was used.
Same check every time, same position like on the side stand.
No drips ever on the floor. Wipe the bottom of the bike and Look for any little bit of oil...
YES, even take the derby cover off and see the level of the primary.
IF High OR over flowing While On the Side Stand... You found a leaky engine seal on the crank.
I doubt from reading this Thread "that" being the issue BUT eliminate it by checking.
If you are using oil (a lot) it will show as Black carbon on the plugs..
(Jack asked about the color of the muffler ends?) Carbon there will usually be flaky soft in short term...
Remove both plugs.
Careful NOT mixing them up from front to back..
(I NEVER remove them on a Hot engine OR threads can be ruined)
Look to see IF one is Black or both? ... Report please.
The plug condition would tell ME if YOURS is MY suspected problem..... Valve Seals MIGHT be bad... Loose and allowing oil to go by.
YES a new bike can have bad or loose seals.
Example:
I have had Seals just Sitting on top of the valve guide ends...Nor properly put on IF at all...
My bike went thru enough oil in MY opinion, after Break-In and HD said Not enough oil use to tear into the motor....
SO I did it myself. As soon as I took of the easy (front) valve cover, I found What They Should Have taken time to find..
LOOSE,,,I fixed it my self..........
I'll NEVER get any Warranty extension as I have had problems with HD. EVEN while under the NORMAL two year warranty...:55:
BURNT TWICE by them.
Now I'm NOT suggesting anybody Else do that.
I DO all my work, apart/together.I DO just fine at that.
Not the boring and machining. I rely on the Pro's for that....
Lecture over
Your problem COULD be the valve seals...
