What i ment was the lower ferring for your legs. I've always called them lowers. I was just wondering if there is any problems with space when mounting a vertical oil cooler on the left downtube? I wanna make sure i can mount the cooler and have the lower ferrings still on the bike. I've never used an oil cooler in conjunction with the lower ferrings. Any help or info would be much apperciated, thanks.
I doubt you will have room to mount the verticle unit on the frame tube with the lower fairings on. I went for one of the 10 row low mount oil cooler set ups. Mounts on the VR studs, and is in front and lower than the VR.
I chose the oil filter adapter with the built in thermostat (185*F), but if I were to do it again, I would not. I think in the Winter, I would just cover the oil cooler instead. Of course they also make a by-pass valve, but that is just something else to leak at the hose connections, and I do not like the idea of leaving the oil sitting in the cooler for an extended period of time while the oil is by-passing it.
