R_W_B
Senior Member
I think I may have figured out the answer to my above question of why they tell you to adjust out half of the preload they designed. I know that hydraulic lifters will bleed down two ways. A small amount bleeds out the side holes that also lubes the walls of lifter bores.
The rest of the bleed down occurs on the relax (back end of the cam lobe) when the bottom check valve doesn't have the upward pressure on it. (these 2 are not quite the same scenarios as "waiting" on a slow bleed down after adjusting the pushrods)
Since air cooled non overhead cam engines have so much expansion, the additional preload distance of the lifter piston spring is needed. Sooo . . I'm thinking that when the specs say to adjust halfway into the preload, that this is possibly needed because that will cover the slack in the preload better when the engine first cranks up and is cooler.
Then as the engine heats up and the jugs start to expand etc, I'm thinking more of this preload (that was previously adjusted out) will then expand as the bottom check valve allows more oil in (on each back side of the cam) as the slack in the valve train increases due to the expansion.
Anyhow that's kinda what I was thinking last night wondering about it. Any comments of enlightenments ?
