lowe16
The very first thing I would do is get that Dobeck unit off the bike . Put everything back to original being very certain the injector wiring gets returned to normal.
Also it is very critical to ensure the injector wiring is secured properly in the locks
of the connector. I would also closely examine each terminal for any signs of
damage paying particular attention to lock tabs. This next sugestion I would consider critical to accurate diagnosis; When you remove the wires from the connector to " reverse the polarity ", before returning the wires to the connector,
install each wire on a terminal in an easy to get at injector. You should feel some resistance pushing the wire on and similar resistance when pulling the wire off.
Do this with all 4 injector wires before assembling the connectors. We are just confirming the wiring can complete a good connection. Good luck
