R_W_B
Senior Member
With the 40 ohm/foot wires on my white sled, 2001 FLSTFI, there is an issue. After installing them and running a test ride I noticed that the check engine light came on with the ignition switch......run/stop in the off position. Before the light came on with the run/stop switch. I turn the ignition on first then from stop to run. I have not checked for any codes at this time.
Taylor sent me an email stating their wires are 350 ohm/foot. Almost 10x as much as the others and almost 10x less than the SE. Could this be a happy medium????? Not sure if I want to spend the money just to get white wires and find out they don't work.
You know there is another facet to this scenario that could also be playing here. It just might be not so much the ohms the 80v (+or-) the secondary capactance discharge is running over to get the edge of the still burning flame, but rather the " stronger flame itself " resulting from the performance wires. The edge of the flame may be of such magnitude that it does not compare " as expected " with the ECM pre-recorded Lab data tables.
At our current technology level a computer is still relatively stupid. It "alone" cannot think or analyse for itself. It is totally dependent on pre-inputted data to compare to. In other words if it was told that chocolate should taste "this" good, and it runs across some chocolate that tastes fantastic, it cannot delineate that this is still good chocolate. It only knows that the chocolate does not compare with what information it was given.
Or course this is a mute issue, since if the egg breaks it matters little what exactly caused the crack. But just thinking out loud.
