+1 on replacing all the seals while you are in that area. I would also replace the quad seal spacer. I would also replace the IPB seal.
+1 on the S&S tapered IPB race but be very careful installing. Once the taper hits the main shaft, a little too much torque and the race will split; very brittle. You just need to get enough of the race on the shaft for the IPB seal to make contact. Once you get the S&S race about .100"-.110" from the main shaft/fifth gear seal, it should be on far enough.
That main shaft/fifth gear seal is a tough one to get out. I have found that working a small screw driver around the inside of the seal is the best way. Others claim using some small picks works well but they usually break a few picks in the process. Good luck!
