dolt
Well-Known Member
Each to his own but I wouldn't put a drill bit near the main shaft. One slip, main shaft dinged and it will leak forever. Drilling and using screws is OK for all the other seals but the main shaft/fifth gear seal is in a tough place to safely drill. Small bit that will easily break in a bind, drilling at an angle in a confined work area and a pretty thin target; not worth the risk IMHO.
