trike lady
Junior Member
Hi All: It's been awhile since I've been on the site but I'm still interested in the rear brake problem. What I experience is when cold the rear brakes work fine but as they heat up it takes more pressure to keep them from slipping. For instance, where I live in NY we have quite a few hills both large and small. We also have quite a few stop lights & stop signs. When cold I can hold the trike on an incline with moderate pressure on the brake pedal but as I use them more and they heat up similar inclines cause the bike to roll forward or back and I either have to use the front brake or stand on the rear brake pedal more. I don't have any squeaking problems but I'm wondering if some of the other explanations may apply. :worthy
Sounds like 'Organic' pads. Once they get hot, they don't work well. Hopefully someone has a "Semi-metallic' pad available; they are a little rough on the rotor compared to organic pads. Do you have 'Brake Dust' on the rear wheels? The trike really needs larger rotors and I'm sure an aftermarket brake company may be working on a set to be offered in the near future.
