I am not trying (at least not purposely) to confuse anybody,and I usually don't believe in coincidences either, so from the beginning I though the cable break caused the engine to die, thinking this was normal behavior when a cable breaks.
Then I found out it has two cables. The throttle cable was intact and the idle cable broken in the switch housing. Couldn't think of a reason why engine would die, as throttle cable was still intact, but I figured I will replace the idle cable and do the throttle cable at the same time for obvious reasons.
So last Sunday I had to call four dealers before I found one who had the parts in stock, thank you
Harley Davidson of Frederick !
Upon returning to the garage I confidently replaced the cables, convinced she would start right up and I could go for a spin to celebrate. Unfortunately that was not the case. Still thinking I did something wrong with the cables I started this post to solicit you help. It wasn't until Monday that I realized the fuel pump didn't seem to work, as I didn't hear the usual 2-3 second priming hum anymore.
Upon switching to run i hear a click and somewhat of a gurgling noise (can't think of a better description) when switching back to stop.
Clearly this is not normal fuel pump noise, and as I determined this morning it is not even the fuel pump, as I still hear those noises while electrical connector is removed from fuel pump, see picture in my earlier post from this morning.
I hear you; but I was hoping other (easier) issues could be the cause for the pump not working.
Replacing the pump seems hard and probably expensive. And going back to not believing in coincidences, why would the fuel pump suddenly die the same split-second my idle cable brakes?
You are not the only one. But I am not giving up, and am convinced that between my tools/determination and all you guys help, we are going to fix this.
Maybe I should also try to figure out who the patron Saint of motorcycles is and and pray.....
http://www.hdoffrederick.com/default.asp
