dolt
Well-Known Member
21k on the lifters.
I didn't check the pistons through the spark plug holes but I did get a good puff of air and the lifters were bottomed out. I can easily jack it up and do it again if need be, but I'm relatively sure I got it right.
SE pushrods. 2.5 turns. Adjusted fronts first, let them bleed down, rotated rear tire till I heard the puff and ensured the lifters for the rear were bottomed out and adjusted them.
It's not crazy loud but it is different and I have certainly heard worse. I may just be trying to make something up since I don't get to do this as often as I like so I'm not 100% trusting in myself.
I have adjusted pushrods more times than I can remember and I was sure that I always had them right. The last time I installed new cams in one of my bikes, I fired it up and immediately knew I had one the was off. Put the piston at TDC on the compression stroke and sure enough, one was loose.
I would go to 3 or evern 3.25 turns with those lifters and check to be sure the piston is at or very near TDC to check for any loose pushrods. After you hear the puff of air, use a plastic straw through the spark plug hole to bump the piston to TDC or just before or after; then check the pushrods before turning another 3-4 flats.
if the valve train is still noisy after making sure pushrod adjustment is dead on and you have added more preload on the lifter; replace the lifters. You can spend about $60 for a set of CompCams VThunder 850-1s, $130 for a set of S&S standards or $270 for a set of S&S Premiums, Gatermans, Woods, etc. Either the CompCams or S&S Standards will be suitable for your application; just depends on how much you want to spend. I consider lifters a maintenance item in a Harley motor with performance cams, more compression, etc., etc. and replace them about every 25K miles.
