dolt
Well-Known Member
the S&S 510 is a gear cam, & the biggest you can install w/o head work. thats what i have in my '09 t/g, and now in my 03 r/g. as you know if the shoes go, so goes your oil pump etc. good luck.lb
Your '03 valve springs will not accommodate cams with more than .510" lift, as you state but the S&S 510 is available as a chain drive cam as well as a gear drive cam.
The '05 and later models can accommodate cam with .600" lift. Headwork should always be matched to the chosen cam but has nothing to do with what cam can or cannot be installed.:s
