Do I sense some frustration DR?
Nope - did I hit a nerve with my heavy dose of reality?
simply don't feel it's something that EVERY ONE of us who installed this compensator need to do ASAP.
I can't speak for ALL but I think, DON'T KNOW, this one got past them. When you hold the comp and shaft extension in your hand, it's easy to see how no oil can get on the extension bore. On the outer side they put the fiber washer in with the lines which I assume are to let oil in. On the inner side, there are the 2 machined flat bores that go together with nothing in between. The fiber washer is for wear (I think) and the lines aren't deep enough to let oil in. The inner bores are pressed together when you torque the bolt to 140 ft/lbs so there is just no place for oil to get in. I realize the sprocket doesn't spin on the shaft extension and only rocks back and forth under different loads but it still needs some lubrication, not much but some. With the parts fitting together so tightly it would take pressure to get oil in there but it's only a splash system in the primary. The oil grooves guys are putting on the sprocket MIGHT be the solution but I don't think there has been enough testing done that I know of to say this is the final solution. I do feel it will be a big improvement because smarter guys than me came up with this and it seems to be a big improvement. Hoople's endorsement makes me feel better about doing this. It won't be long before we see what Harley's solution is and I'm sure they'll find one but I hope it's made public ASAP so guys who have the SE compensators can fix there's or get the new and improved one. Maybe they'll use Jack's solution and put a grease nipple in.So let me get this straight. ALL of you are convinced that HD engineers had never heard of fretting, were not aware that it would occur in this application, and did not do a thorough analysis and simply decide that it wasn't that big of an issue. I know we all bash HD a lot but that's really giving them NO credit at all.
ts. It won't be long before we see what Harley's solution is and I'm sure they'll find one but I hope it's made public ASAP so guys who have the SE compensators can fix there's or get the new and improved one. .
This is unbelievable! My SE Compensator is the one mod I've done that produced an instant and noticeable improvement. Now, I gotta worry about it fretting. Fella's I've been on this site for years and ya'll know me..I ain't a troll or generally a negative person but I'm getting tired of these issues. Overheating, weak fairing brackets, crank shaft runout..it's seems non stop. Just when I've convinced myself my bike doesn't have an issue....another one pops up.
