J
Jack Klarich
Guest
Wow, having only experienced my H-D Sportster for only 3 years, I am amazed how things can be so embedded into a design that should have been sorted out during the R&D phase...kinda reminds me of the cheap O-rings that brought down the multi-million dollar Challenger.
Looking at the design and photos, I would say that expecting oil "splash" to lubricate that area by grooving the sprocket may be fruitless, but only by doing so...along with future disassembly/inspection to see if the shaft is wet is only way to be sure. Maybe Hoop being in there already could do the deed and report back...inquiring minds want to know.:s
As that rust and lack of lubricant and failures of even freshly installed SE replacements soon afterwards means othe area is isolated, with only the moisure condensation from temperature changes able to get in there.
I would probably use high temperature marine/bearing grease in there to start...and likely there should be a lubrication groove concentric to the load bearing surface to retain the grease just do be sure as only pressurized oil would be the only way to get in there...JMO. :newsmile091:
Maybe The MOCO out smarted them selves on this one and hoped for better results. I know I am dating myself on this one but we never had this problem in the old days in fact the older FL models had a grease fitting HMMM makes me think of a possible fix:s
