Hoople
Account Removed
Should be quite straight forward this time; don’t think you really need to pull the clutch basket?
I did not remove the clutch basket on mine. Actual R&R of the sprocket was less than hour. No point in matching sprocket to chain, but chain (if removed) should go in same direction. I re-used my primary cover gasket and have no leaks. It really was a snap. Used a 1/8" round ball carbide bit. Took 10 minutes per groove by hand.
