well at any rate, it sounds to me that the smart tune is kind of a "street" dyno method. In the manual for the old version tuner it says to change all the cells in the AFR table to 13.1 then using a AFR reader adjust the VE to accomplish 13.1 in all conditions and then adjust  the AFR table to desired AFR.
              It sounds to me that with the smart tune you would be doing the same thing in reverse, just using the O2 sensors instead of an AFR meter? Correct?    :newsmile082:
I guess what I'm saying is what difference would it make if you callibrate to 14.6 or 13.1 as the computer will use the VE tables for any thing in open loop anyway and not the O2 sensors to calculate fuel delivery.  :newsmile082:
