RibEye
Senior Member
Re: spark plug poll
Wow. That does seem to be alot of advance there. It leads me to believe that what I am hearing when I roll on from low rpm is not ping but knock. That is a different sort of animal indeed...one with big teeth.
Enjoy,
Rich P
And the Ion Sensor needs to work properly so why take the risk of running anything but the right plug.. Take 1 look at some of these spark advance numbers from a stock factory map from my 2009. (If it displays correctly) the left column is RPM top to bottom and "engine load" is from left to right with far right being WOT.
Look at all the high 30's and 40's of degrees of advance.Your engine could never live a long life without some sort of spark retard kicking in when you quickly twisted the grip from a light load map in the 3000 RPM range.
Harley Davidson Community
Enjoy,
Rich P
