Well, that article almost makes our discussion moot. If I understand correctly any changes to our motors, even a Stage 1, messes with the ion sensing?
Oh fine, now you tell me. Just bought the HD plugs to test, $8.When I took a Brand new HD 6R12 spark plug and chilled it in a refrigerator I measured the resistance. Just under 35K when @ 35 degrees F. Began to warm it up with a heat gun and the resistance fell and fell and fell until it settled at about 1K (temp was at least a few hundred degrees). I have experience with temperature coefficient resistors but this is a little extreme.
So after taking a HD 6R12 and heating the electrical connection end with a heat gun it will unscrew out of the porcelain. Turning the plug upside down and tapping will result in the resistor and pressure spring falling right out. After taking a look at how they are made, it is no wonder there is no consistency from plug to plug..
So far everything seems to indicate the resistance of the plug is meaningless. 34K to 1K with everything in between just does not make any sense to me. If temperature compensation was that important, it would be in the Coil module and not in the plug. So at this point I would say that plug resistance is not something to be concerned with. That is to say as long as it is somewhere between 30K and 5K I don't think it will affect the Ion sensor operation.. (just my opinion at this point) Hopefully Delphi can clue us in with more detail.
Welllllllll....the stage 1 only adds more fuel and air basically but really does nothing to the resistance in the secondary ignition system.
nt.
Detection is dependent on the values calibrated in the software that represent knock, and are based on a stock engine ( or a known modified engine such as the STAGE I,II etc.) with a GIVEN set of Production intent parts.ie , Spark plugs, wires, and even compression ratio can and does change the resistance at the coil.
