I do not understand what this means => "Stroboscopic lamp plugged on rear spark-plug cable lights up well since motor start"
Strobascopic lamp or stobe light or timing lamp is a lamp used for setting dynamic ignition timing each pulse of fire from the coil will induce a flash from the lamp normally connected between the plug cap and plug or has a sensor that is hooked over the high tension lead it is powerd from a 12v source often the vehicle battery and as such produces a pulse of light with every pulse to the spark plug
IE if it flashes the plug is sparking
