its a 32amp kit, i believe the harley one comes with a new stator and rotor with much stronger magnets and a primary cover gasket, its been a while since i have installed one so i dont remember if thats everything that comes in the kit, i know there are after market kits that come with stator rotor gasket and a voltage regulator, in my experience the HD one has done the trick just fine every time.
10/4. Interesting. Yep 32 would be a nice boost.! Tks!
Not for sure the manf. (wasn't HD) I do know it is made in the USA -But I had my indy put a 32A on my 87 FXRC - $249.95 + tx and 40 bucks for a labor charge. I will give him a shout tomorrow and ask the name brand.
Thank you for the replies. I will get an ameter and check th amps to the starter. This bike has well over 50k on it and most of the components I replaced had wear but I agree I need to trouble shoot the system and go from there. I have put in a new charging system and regulator since I had the primary cover off anyway. The starter did spin the engine well with the plugs out. When I get the meter and and put the cover back on I will check the charge to the battery. Thanks...Rigidscoot
check with a meter- the plug where your stator wires plugs onto the housing. didn't pinch a wire when you put the charging system in did ya and what amp/size did you install????
