Hoople
Account Removed
T Just out of curiosity, does the Solenoid plunger and its related spring ever cause a problem with the copper washer and the stud contacts?
Thanks Rigidscoot
Electrically...If you wanted to test the studs and washer contacts, measure the voltage drop (if you can probe the stud "in" & stud "out") while the engine is cranking. The closer you are to "0" volts scross the contacts, the better. You can do the same for your heavy cables. Measure the voltage drop scross the cable while pulling a load. The closer to Zero, the Better while you are applying a heavy load. I would be suspect of anything that was more than 1/4 volt..
I am glad others jumped in because I really can't explain some of your findings. Maybe when Glider gets back he will have something to add.
