free website stats program Suspension Question? I think... | Page 2 | Harley Davidson Forums
been lowered then i would say as ride height is listed as 5.12 by the specs i found
Manufacturer (Make) Harley-Davidson
Model Name FLSTCI Heritage Softail Classic
Year 2004
Category(class) Cruiser / Chopper / Custom
Engine
Engine Capacity (Displacement) 1449 ccm (88.42 cubic inches)
Engine Type V-type, 2 cylinders
Bore x Stroke Ø95.3 mm x 101.6 mm (Ø3.75 inches x 4 inches)
Bore/Stroke Ratio 0.94
Stroke 4
Valves per Cylinder 2
Timing System DOHC
Fuel System(Carburetion) Injection
Cooling System Air
Powertrain
Gearbox 5 speed
Chassis/Suspension/Brakes
Front Brakes Single disc
Front Brakes Diameter Ø292 mm (Ø11.5 inches)
Rear Brakes Single disc
Rear Brakes Diameter Ø292 mm (Ø11.5 inches)
Front Tire 90/90-16
Rear Tire 150/80-16
Dimensions
Overall Length 2391 mm (94.13 inches)
Seat Height 648 mm (25.51 inches)
Fork Angle (Rake) 32° degrees
Wheelbase 1630 mm (64.17 inches)
Ground Clearance 130 mm (5.12 inches)
Dry Weight 322 kg (710 lb)
Fuel Capacity 18.9 litres (4.99 gallons)
Performance
Max Torque 102.00 Nm (75 ft*lbs) at 3500 RPM
Well, I guess my bike has been lowered. Hopfully the dealer can adjust it for me tomorrow.
How can I tell how they lowered it?
Dumb question here, was the bike on the stand? :s
The lowering is done inside the forks and is reversible usually with the right parts.
