NEWHD74FAN, what about Avon's mixed up psi specs??
J&P cycles where I bought the tires gave me the correct answer. Go with what is says on the tires, Max weight, Max psi cold. The Avon tech person must of thought I was talking about the reinforced tire, and I have the Venom-x non reinforced tire. venoms do not handle well loaded up for a road trip. oh well, it is what it is, next time it's a Metzler or Dunlop. I just want to share this so nobody else puts the wrong tire on their bike.
The maximum tire pressure listed on your tire is the manufacturer's maximum...NOT the recommended tire pressure for your motorcycle. There should be a decal on the frame of the bike indicating the wheel/tire size and MOCO's recommended tire pressure for your bike...PERIOD (caveat it should be the starting point for different brand of same/compatible tire size).
IF you changed the tire size, you may have to adjust the starting pressure a bit higher, but NEVER exceed the cold inflation MAX listed on the sidewall, the chance of a sudden deflation or blowout due to excessive pressure is NOT RECOMMENDED by manufacturer think "product liability here". J&P Cycles personnel are in error to think and obviously are not bearing liability with such a verbal recommendation.
