The majority of the weight is on the back![]()
Cheers mate...:worthy
Mine were low and I went with the amount on the tire. Bone jarring! Saw and read this thread and will go with what is listed here (I received no manual with my used bike either.)
The MAX pressures shouldn't be used in the tire and considering the tire pressure increases as you ride from heat, the max pressures would then be about 3-4 lbs over the max. Never run the MAX pressures printed on the sidewall.
But max pressure on every tire I've looked at states Max load *****lbs at **psi COLD I figure them tire gurus are taking into account that the pressure will go up when the tire gets hot.:newsmile040:
