So here's what I got:
From the manual.
2. Check friction plates as follows:
Wipe all lubricant from the friction plates.
Measure the thickness of each plate with a dial caliper or
micrometer. If the thickness of any plate is less than
0.143 inch (3.62 mm), discard the friction plates and
replace with an entirely new set.
Look for worn or damaged fiber surface material
(both sides).
What is the nominal thickness of new plates?
My measurements
Disc:
1 - .143” (inner narrow disc)
2 - .1425”
3 - .143”
4 - .1435”
5 - .144”
6 - .1415”
7 - .1435”
8 - .145”
9 - .145”
Metal discs: No burning/blueing, scoring or other obvious damage.
So it would seem the friction plates need to be replaced.
Now questions arise.
Is grinding a normal result of spent plates?
Should I be looking further or should I try the new plates before I needlessly dive deeper?
Should I replace just friction plates or metal as well?
Where and what brand to get?
I called the dealer where I bought the bike and they want $283 + tax. Not sure if that is entire pack or just friction plates.
From the manual.
(both sides).
My measurements
Disc:
2 - .1425”
3 - .143”
4 - .1435”
5 - .144”
6 - .1415”
7 - .1435”
8 - .145”
9 - .145”
