black02flht
From trial and error this is what I found works best.
I don't like to drill the slide and I shim (lift) the needle with 2-#4 washers for best results.
Glider,
Is it easier to pull the carb off or to raise the tank to gain access to the carb top? I pulled the carb off the intake but could not figure out how to remove the cables. So I put it back together again. ANy help would be greatly appreciated.
Thanks,
