BUBBIE
Well-Known Member
You are absolutely correct about the spacer. The thing is I took apart my failed front wheel bearings and found out some interesting things. The bearings used by HD are just ordinary 6205 2RS electric motor bearings. Just an ordinary type lip seal which was never designed for driving wind or rain. *****
Pop the seals out on a couple of HD factory bearings, take a close look and have a laugh. ***** Even the best of the best 6205's won't take any high wind exposure, much less driving rain exposure.
I believe it starts out as a Seal failure which leads to a bearing failure.
Hoople
Do you think anything covering the outside of the stock OR Your replacement bearing Like a CAP would Help???
I think IF something like a Thin Tin (snoose can lid) made to fit in-between modified spacer and cover the bearing??????
Would that do the trick?:coffee
Mind You I don't Chew nor am I looking at my Bike..
