If same lube goes in all three holes, one could ask why...? The simple answer HD Syn 3 is a compromise:
Engine - most stress, widest temp range, most pressure (5 micron filtration), clean consistant oil viscosity must prevent bearing film shear or break down, needs lowest friction, so very slippery oil like Mobil V-Twin 100% Synthetic is recommended. HD Syn 3 is a synthetic blend, a compromise, so not the best choice for engine life.
Tranny & Chain case - thicker gear oil 85W-140, extra additives for hypoid meshing gears, slinging oil from multi-plate chain needs to stay where needed, not coating the cases...100% Synthetic gear oil by Spectrol, Redline, BelRay, Amsoil or others are all very good.
Wet Clutch - oil wetted, 100% Synthetic may be too slippery and actually shorten life due to slippage...use Petroleum based oil MA JASO rated made for oil wetted clutches. If a Sporty where both the tranny and clutch reside, petroleum based 85W lube like Spectrol Primary Chain Case gear oil should be used.
There are special threads, that discuss plenty of opinions expressed, and polls for data to help you decide.
