well when i did the oil change,i used the servive manual,and it showed me that and i took off the screw and there was only a spring and at the bottom was a inch long peice of metal,it looked like a 22 shell casing,there was no screen,in the pic in the manual it showed a spring around a screen,but that spring that came out would not fit around the screen if the was one.so i cleaned up the metal thing and it slid down in the hole and i put the spring back in.am i missing something,or is this a new thing that somebody put in there.that peice of metal thing was a perfect fit no slop in it like it was made for that,and that spring went inside of that..i looked with a flash light and no screen..
did i remove the wrong plug..the other one next to it was not a screw driver slot its like a acorn bolt head..when i looked at the manual im pretty sure i removed the right one it showed it in the pic too..if i remove the acorn one today and check that one is oil gonna squirt out oil is that under presure now .i looked at that link that smitty901 sent and i think i removed the wrong one.my manual didnt say to remove that one...
