I put another brand of rear wheel stabilizer on my '05FLTRI. I did this because after I made sure the wheels were aligned and balanced correctly and the neck bearings were adjusted to specs.,I still had a wobble in tight curves. The stabilizer solved my problem. If I had the amount of weights on my tire that you have I would want to know why. Do you have aftermarket wheels? Do your tires wear evenly? If you have changed you tires did you make sure you got the proper rated tires for your bike weight?
