2008 Streetglide - 1700 miles, stock cast wheels and stock tires.
Conclusion:
I have checked the bikes alignment, balance of the tires and quality of engine mounts.
I purchased a True-Track, ran it 100 mile installed, removed it and ran it another 100 miles.
Positive - I can say that there is a more solid feel with the T-T system installed. This can be very difficult to explain because what is perceived to me might be different to others. The yardstick that I used was, did it remove the 'flat tire feeling' and I feel that it did remove 80% of it. My drive way is about 1000' long and I immediately had the feeling that everything was connected (less sloppy) even before I reached the highway.
Negative - The trade off is a little more vibration especially around 2100 to 2200 RPM's.
You loose about 1/8" clearance, I found this out when I pulled into a gas station that I have used many times before. Crossing a small depression from highway to parking lot, it scraped something used to strengthen the brace that T-T calls a Dogbone. Didn't harm anything just never did it before and left scrape marks about the size of a quarter on the Dogbone.
In summary, after all the settings that have been checked and verified this is the only thing that I know of as a possible solution to the "Flat Tire Feeling''. Whether I want to accept the vibration trade-off will be determined over the next 100 miles.
Thanks to everyone that offered solutions and comments, you all are what makes this site great.
Jim
