LittleKim
You're going to find a bit of difference in the bulb you just ordered when it comes time to adjust it.
You'll find that it has a horizontal beam as opposed to a spot light type of beam like the stock bulb that can be used to keep it lower than the on coming drivers and can be raised above the usual setting like Gary recommended and it is also in the owners manual.
As long as the horizontal beam isn't too high to blind oncoming traffic, it can be raised up a bit for awesome results.
I use the trial and error method on the garage door at night to get the maximum out of the light as far as adjustment without causing a problem for on coming drivers. You'll like the results you get with that bulb, It's a whole new driving experience at night.
