Have you taken the headlight out since then to look at the plug? I ask this because I had baught one of those blue colored lights that was still 55/60 watt but it was stated that the color was hotter or something like that, but anyway my bulb burned out and when i pulled it out the plug was discolored from heat(allmost melted).That got me a little worried and i put the regular light back in. If you dont mind,when you get a chance, could you look at yours and report back on the condition of your plug and wires? I did the math on the 80/100 watt and it draws about 3.3 more amps on high beam than the 55/60 watt.I have one in my 2007 Softail Standard, and a friend of mine has one in his 08 Fatboy. I haven't had a problem, and I've been running mine for about 15,000 miles so far. It really does make a huge difference when ridding on dark back roads. I don't think there's an actual "wattage" difference in the bulbs, but if there is it's minimal.
I would like to get a brighter light but wasnt sure if it cause problems as time went on. Dont want to screw anything up in my electrical system. (charging system)I have looked and it looks fine, but I'll do one better and get a picture when I get a chance and post it on here for ya.:s Don't ya think you should blow a fuse before you melt your wires:dknow
