Scarletride
Jack and Smitty are both right. Get your speed and gear right before you enter the turn and roll on the throttle as you go through. Remember to look through the curve not at the curve. See where you want the bike to end up not where it's at. Like Smitty said, watch for sand or gravel in those corners, that will bite you quick. A course, whether it's the beginner, or advanced riders course is a good thing. It definately can't hurt. Ride safe and keep the rubber side down.
Thanks Smitty and tramp 60. I think I realized I need to get the speed right BEFORE i enter any turn and lean the bike. I ride with riders of all kinds of bikes, but mine is one of the few 800 pounders so I should not expect to enter and exit turns at the same speed they do.
Your advice on the advanced course is well taken and something I am going to do as I know my inexperience was probalby the main factor here.
Fortunately my wife went from "thats it, its over, get rid of it" to understanding that stuff happens.
Try one of the flexible air gauges from Matco or Snap On:s or this one Tire Gauge with Flex Hose
thanks I will do that
Are you riding in the center of the lane?Lot of oil sits there.Glad your OK :small3d026:That's a big bike to trail ride with.
That is exactly what went through my mind after I safely crossed the other lane without getting hit. Up until that point I was hoping that if a car was coming in the other direction it would be a Smart car.
My opinion from what I saw is it had to do with weight transfer.......when you set up for a turn and start to lean you can't upset things abruptly or transfer of weight can cause you to lose traction.
BTW he was riding a Road King as well.
I can say I have never had this problem because I drive slow on the curves......HD's are cruisers not racers![/QUOTE]
Thanks. I think you are right about 800 pounds being a bit much to screw around with while negotiating a curve whether going on or off the brake. I always knew not to put the brake on but had been entering turns with the rear brake lightly on on the initiation of the turn many times, then come off the brake as I lean. Maybe Ive just been lucky up till now. Thanks again for your response. i will change how I ride because I love riding and I love living
