That will be the accelerator pump it is operated by the rod that goes into the side of the float bowl it should be squirting the fuel straight down the centre of the carb throat if it is off a bit you should be able to grip with a pliers and rotate it to get the fuel in the right direction
I need to read this thread all the way through again and take the dog for a walk top of the hill overlooking the stunning scenery here is good thinking space
