Maustarman
S&S recommended rod side play is .015" to .035"
Will measure to check.
By watching the video it does look a wee bit more than .035" however a quick test may be to try a .035" feeler gauge in the gap and see if there is still some movement
Update on this post as I got round to opening the relevant book but this is for post 1990 sportsters I do not have info for the 1988 but it may be similar
connecting rod side play at the crankshaft 0.005 to 0.025 service limit 0.030 so best check with a 0.025 feeler gauge between flywheel and connecting rod
Checking right now
Guys, that's not "side play" we are seeing. Side play would mean the rod moves side to side; the center line of the rod moves side to side but stay perpendicular to the centerline of the crank. That rod does move side to side but the centerline of the rod does not say perpendicular to the crank.
This makes sense I guess ...
Ok... I measured the gap in between the rod and the wheels...
0.24"
That's what I got...
I'm at the mercy of y'all's opinion
What next
