Ok... I decided to put the top end back together with a ticker compression gasket *Just to check if the sound was gone or not.
I figured out how to adjust the pushrods since they didn't have any markings or anything.
I just went out after letting the lifters bleed and double check the adjustments.
Started the bike and YES! The sound is gone
I check compression and I got:
230 PSI in the rear cylinder &
215 PSI in the front cylinder.
How do those numbers sound?
Now, I'm having another problem here:
The bike only starts with the choke all the way out and when it starts its really high revs. Next- as soon as I disengage the choke the bike dies.
What did I do wrong- why is it doing that? (Used to start easily and idle nicely)
Is it Carb related, air leak some where?
