BUBBIE
Well-Known Member
Great information...Thanks
After adjusting the pushrods, do they have to be re-adjusted from time to time or is it set-it and forget-it.
My opinion on this is:
set and forget
Once Set properly, Lifters should work well and Not Need further adjusting UNTIL you hear a tapping from the lifter area again.... Then more than Likely you need a new lifter or set Again...
I had one Lifter go bad after a few thousand miles of all being New... It needed to be replaced with new one, the push rod set again and it was Good to go..... Never needed to re-set any of the others,,,,, if done Right the first time.
