Doc, if you have not put the primary cover back on, would you be able to measure for me how much torque it takes to break the crank from a stationary position? I would like to know what the parasitic drag of a 96 is when cold.
It would help in starter, battery draw issues down the road.
OK here you go - everything inside the primary installed and adjusted, tranny in neutral, spark plugs removed, started with torque wrench set pretty low and adjusted up in 5 inch pound increments until the crank turned before the wrench clicked. The magic number was 150 inch pounds. Hopefully this could help someone down the road!
Sounds to me like you're good to go Dr. Some folks are not able to get any movement at all ot of the sprocket..some say about the same amount as you have.
I would say...get on with it. Clutch basket & Chain...then the tension shoe...might just go ahead and adjust the clutch before you put the primary cover on.
Lets go..yer burnin daylight!!!!!
Yep, you have to adjust the clutch since you had the whole thing removed. Luckily I've got 2 weeks worth of daylight to burn since I'm on vacation!
