dolt
Well-Known Member
Dolt, I have a couple of questions. Why the 585 instead of the 551? If I am reading the S&S literature correctly, they are recommending the 551 cam for my application. Second, specifically what are you recommending I use when you say to "Upgrade the inner cam bearings, cam chain tensioners, oil pump"? Also, what kind of mileage should I expect from this combination? Thanks for your input.
The 106" kit includes flat top pistons but I don't know the dome volume. I have assumed it to be -3cc but not sure. The 551 intake closes at 19* ABDC, which will generate corrected compression and CCP way to high; like 10.4 corrected compression and near 220psi CCP. If I were you, I would check with S&S to verify the piston dome volume and calculate corrected compression and CCP; try to keep corrected compression in the 9.3-9.4 range and CCP in the 185-190psi range. Assuming the same -3cc dome volume would set corrected compression at 9.4 and CCP at 195psi (sea level). Of course that is based on 85cc chambers which is pretty standard for OEM heads. So, that's the reason I like the 585 more than the 551 and I like the additional lift. Check with S&S for the dome volume, do the math.
The OEM inner cam bearings are INA bearings and you should replace them with a full compliment roller like Torrington B168s or the SE bearing. At 125K miles, the tensioner shoes and oil pump should be replaced. They may still be with the service limits but why invest the money in a new build and not start out with new tensioners shoes and oil pump? As for an upgrade, Zippers make a dual piston tensioner that is supposed to be an upgrade; haven't installed any so I can't speak from personal experience but I hear they are better. As for the oil pump, a new OEM pump will get the job done but if you have an extra $450 laying around, the Dan Thayer 3 stage pump is the bomb but not necessary for your project.
Mileage will depend on how you use the throttle, could be anywhere from 36 to 44. It all depends on how much self control you have.:naughty
As usual, JMHO.
