dolt
Well-Known Member
My question: if quick install push rods were used couldn't they be backed off (or removed entirely) until the valves were seated and then proceed with the test as usual?
Yes, you could leak down that way; just a lot of trouble to go through for a leak down test. One could also remove the rocker covers and the rocker supports as well. That would be less time consuming but still a PITN.
jennmarr said:Finally got the info on the pistons. According to S&S Technical Assistance, each valve pocket has a volume of 2cc giving a negative dome value of 4cc.
I would still be inclined to the 585, assuming chamber volume is 85cc and head gasket thickness at .030", what it should be for tight squish.
TMan's 590 or 600 would work well, as would the Andrews 57. Having said that, for a two up touring application, I would be more inclined to a lower lift, shorter duration cam like the Andres 37. Still plenty of compression and torque; you would probably see as much TQ, perhaps a little lest HP from the 37 as with the longer cams but with less wear/tear on the valve train and proably a quieter motor. JMHO
