dolt
Well-Known Member
Dolt, that was not the recommendation I was referring to. In fact I did not see the note you quoted. What I had seen was included in the information that accompanied the 106" kit. I will try to look it up again when i get home tonight. One other caveat that may impact this discussion is that the note referred to the 551 EZ Start cam. I am certainly not married to any particular setup at this point and I am not trying to argue with you. I just want to understand where you were coming from and why you were making the recommendation that you did. I had an Andrews cam in my last bike ('86 FLHTC). 80" Evo that I was very happy with. I certainly do not want to create any driveability issues for myself.
On a related note, I saw on another thread that you recommended a couple of other shops for head work. Just wondered if you knew of one in north central Indiana? I am not opposed to shipping the heads to Maine, but if there is a local shop capable of doing the work, I would prefer to stay local. Thanks again for the input.
Please don't misunderstand; I did not intend to come across as argumentative and, if I did, apologies. Bottom line of cam selection is to collect the data and do the math before selecting any cam and then build around the cam set.
The EZ Start cams would address high CCP but not corrected CR. I don't like the EZ Start cams for the simple reason that one cannot get an accurate read of static compression with those cams. That may not matter to some but I like being able to diagnose top end issues and compression and leak down tests are the two primary diagnostic metrics.
I understand the desire to work with someone local; makes sense. However, I do not know of any head porters in north central Indiana. Atwood Performance is located in Newark, Ohio; Arn is the owner/porter and is quite good. He may not be local but if only a 3-4 hour drive away; at least you could meet the guy, talk face to face and Arn can help with all your motor questions/isues and what works best with his heads.
Atwood Performance
