With the tire aligned this way the bike will want to fall or move to the left. Just as you push the left handle bar right to make the bike go left. As with counter steering the shift to the right will make the bike fall to the left. The gyroscopic effect has the rotating mass wanting to go stright, once the mass is offset (tire pointing right) the mass will fall to the path of least resistance (fall to the left). If when you get the alignment correct and the bike still wants to move to the left I would check to make sure the front brake caliper is retracting.
