Well I have always remembered this thread since my bike just 'barely' pulls to the left. I was glad mydeluxe got his bike running straight but I was amazed that anything inside a degree would make ANY difference, especially since the manual says as long as it's within 1 degree it's ok.
Well about a week ago I bought one of those nifty digital angle meters at H.F. like the one mydeluxe had. My old one was a needle type with only 1 full degree of readable accuarcy. So anyhow I put the bike on the lift, aimed the front straight ahead and stuck the magnetic reader on the front and then the rear brake disc.
I got a reading of 89.90 degrees on the front and 89.80 degrees on the rear. So I'm thinking that can't be worth fooling with. But my bike has always pulled a little to the left (I've got the rear alignment dead on and fall away is ok). So I sit down and do a few calculations and come up with these numbers
At 10.25" radius (20.5" dia) average inches of vertical distance
from center of axle to edge of tire (19 front tire, 17 rear)
1.0 degree of difference in vertical alignment = 0.1788962 inch (almost 6/32 inch or 3/16) (89 degrees to 90 degrees)
5 tenths (0.5) of a degree of difference in vertical alignment = 0.0894481" inch (almost 3/32 or 1 and half 16's) (89.5 degrees to 90 degrees)
1 tenth (0.1) of a degree of difference in vertical alignment = 0.01788962" inch or almost 1/64) (89.8 degrees to 89.9 degrees)
Well after looking at the calculations I can see that it is believeable that mydeluxe's 7 tenths of a degree could affect the bike. My scenario is the one on the bottom and I don't think it to be a problem since it is in fact mydeluxe's final setting.
BTW these little digital meters are really cool. It automatically shows the readout in relation to it's axis (text upside down or right side up). It magnetically sticks right to the brake disc and you can press the HOLD button and remove it and the reading stays. But then mydeluxe already covered all that back then.
Here is the link to the meter.
Digital Angle Finder / Angle Gauge
And here is a pic of it on the rear brake disc.
