mydeluxe
I will try the light tubes again. I understand it better now plus it looks like an eraser fix, than the inclinometer. Will get back after I try it. Thanks again Hoop & RWBAnd yes to what Hoop is saying.
Regards MD
How did you support the bike in an upright near vertical position while you checked the alignment.
put an inclinometer on the side of the frame backbone and compare it to the reading on the front and rear brake disks.
This would help you see if the frame has any twist to it.
It didn’t it was out by 0.70,
*****************************************RWB, I truly don’t think the frame is bent, but I do think the tires are not parallel. I did go to Harbor Freight and got an inclinometer I bought the better one because it had magnets on it ($30) to help with the alignment. I attach an inclinometer (angle finder) to the front rotor and noted the reading. It doesn't have to be perfectly vertical, but the closer the better. Then attached the inclinometer to the rear rotor and see if it reads the same as the front rotor. It didn’t it was out by 0.70, I adjusted the top stabilizer link 1&1/2 turns so the rear rotor is parallel to the front. See pictures below.Afterwards took bike out for 40 mile road test and no tracking to the left at all…
RWB, I truly don’t think the frame is bent, but I do think the tires are not parallel. I did go to Harbor Freight and got an inclinometer I bought the better one because it had magnets on it ($30) to help with the alignment. I attach an inclinometer (angle finder) to the front rotor and noted the reading. .... .... Afterwards took bike out for 40 mile road test and no tracking to the left at all.
The inclinometer pics show 89.80 - 89.70 = 0.10 degrees difference.
I assumed those were the "after" readings? Maybe not. Seems like either way, that is a critical adjustment to say the least.
I need to pick me up one of those tools for sure. Looks better than the 1 am using by a long shot. $30 is a steal.
Oh ok, well even so that is still less than 1 degree off and even the H.D. manual says it is acceptable to be within 1 degree.
