Rocket,
While you are in the nose cone, make sure you get an eyeball on the inner tensioner. This is a bit of a challenge, but patience and perseverance will prevail (especially if you use a disposable dental mirror)!!
If either tensioner is 1/3 or more worn, replace them both. This will reset the clock for you and postpone when you have to shell out the grand for the conversion. Latus has the tensioners for $66.50 each, but Zanotti's sells them for $44.13 each. So for around a HD (hundred dollars - included the gasket), you will have a little peace-of-mind until the piggy bank is ready!!
Here are the p/n from my bike. I bet they are the same for yours although the suffix letter may change indicating an up-dated part:
39954-99a (primary - outer)
39964-99a (secondary - inner)
25244-99 (gasket)
11301 (o-ring - 2 for pump)
11157 (o-ring - for pump)
While you are doing all this, you might think about replacing the OEM relief valve spring (26210-99) with the Baisley spring (LMR-002). This will increase oil pressure by about 10-15%.
25244-99 (gasket)
