Jonas
Junior Member
Welcome aboard, Jonas. Not that I'm an Old Salt here, myself
That special price of kit and labor for less that $600.00 really IS a special. Should I see that in my local area it would be difficult to pass it up no matter if I think it's presently needed or not.
If you have the time and inclination to share a bit more info about your gear drive I'm really interested; kit? , do it yourself or shop?, cost?
I appreciate the advice about my waiting and maybe wanting to upgrade after more time to think about it. Perhaps. I know I would were I in my 20s but I'm getting older and more sedate (61) and at this stage in life mostly want a smooth, well running bike with some longevity. The present power and speed of the bike keep me white knuckled enough as it is.
Yeaaaaah, old school gear drive would eliminate lots of problems, but in reading posts on this forum can present other problems, too.
Rocket thanks for the welcome. Are you retired Marine? Jackonville is my old stomping grounds. I was there on and off for six years. My first wife is from there. Marine Corp 82 - 88
I love the gear drive.(You have to have someone that knows how to install them put them in). Also you crank runout has to be less then .003". I went that route because it was proven. If I did it again, I might go with the HD Upgrade. But I have no complaints with the way I went.
I had Andrews 26 cams installed at the same time, plus dyno tuned. My bike is a 04 RoadKing 88". Stage 1 with Wild Pig slip on's 2" baffle. Nothing special. With the cam and dyno tune. I went from 65hp 65tq (about) to 82HP 92tq. All from the cams and tune. A big benefit was the bike runs alot cooler and is more fuel efficent. The 26 cam is not wild, it is what would be in the bike if not for EPA.
I had to buy the TTS Module for the dyno tune, plus dyno time, new timken bearings and tune. The gear drives took longer then quoted to put in. But I would rather have them right(no noise). It was around 2200.00. Lot more then just the HD upgrade. But it is like riding a different bike.
If you chose to go gears you cannot use your existing cams. I think the HD kit is a great deal with the new oil pump and all.
Good Luck
