Oils for the most part become the choice of the owner as to which is best for them and most have their reasons for the choice. Truth be known that most any quality oil of the right viscosity will do the job, some just do it better than others IMO. I suggest the Mobil 1 being it is a very high quality oil with the right additive packages for the application.
Some post that "I use brand XXX with no problems". It's difficult to tell if they are causing a problem until it is too late, then the damage is already done and is not reversible.
Very few if any of the better quality oils will "cause a problem" but when the cheaper oils are used, they too will not cause a problem until they start to break down (which happens quickly) from the heat and then the problems begin. You can save some $$$ on buying a cheap oil but you will end up down the road spending those $$$ you saved on engine repair/rebuild.
I'm sure that if someone posed a question to you that if you walked down a certain street that something very dangerous to your health could happen but if you went one block over to get to the same destination and you would get there safely, it wouldn't be hard to figure which route you would take.
Why gamble with oils? It's the life blood of any engine!
